Thinking about restoring my HLA pallet forks
nerwin
Nov 13, 2024
316
602
Vermont
youtube.com
This is the pallet forks that came with the tractor. But It's looking a bit rough and I'm thinking it could be a fun project to scrape off the peeling paint and clean up the rust and give it a fresh coat of black enamel paint. I do have issues with the locking pin things on the tines and they are really difficult to slide back and forth so I'm thinking a fresh rebuild and fully grease everything it should be a really nice set of pallet forks.
I wanted to make this post so I can share some pictures of the progress I make on it and welcome any advice.
I'm sure others wouldn't bother but I wanna put my own scratches on it! Seriously though, just wanna fix the rust.
7,756
That is a nice set of forks!
Scraping the paint off... HAHAHA your funny.
That is more than likely 2 part or baked enamel.
Unless I'm completely wrong ( wouldn't be the first time) and it's just cheap paint that's not bonded well.
If the "paint" can be scraped off and it's thick it's not paint, it's powder coat, and that is a real bear to work on.
I don't think it's Powder Coated.
Have you ever use roloc wheels and a die grinder or rust remover disks for a grinder?
Or even better a Soda blaster (my favorite) or Sand blaster.
That would be the quickest and easiest way to get anything loose and rust off of it and prep it for new paint.
If you don't take the latches apart, Oil the pins and slides don't grease them.
If you do take the latches apart then use grease, pack it around the spring to make it last a long time.
Hugo Habicht
G1900
Jun 24, 2024
232
271
Ireland
Scraping off the loose paint bits and removing the rust (not easily done if you don't want to see rust again) is a good idea. The corrosion will continue under the good paint otherwise.
On my tractor frame the paint is mostly good and the paint is tough to get off, so I am debating if I only treat the rusty bits and leave the good parts alone. I think this would be a time saving option.
If I want to clean everything I use CSD disks in an angle grinder on the good paint parts and then sandblasting on everything followed by a chemical rust remover (phosphoric acid, 30-40%).
Nice pallet forks, I would certainly do something to stop the rust and grease everything and make them usable again.
5,420
I have a set of 900# HLAs for my BX23S, it's powder coat 'paint'.PITA.
However If you want to have fun ,come on over, and 'practice' on mine !!!
every month or 2, I just spray 2-3 light coats of gloss black enamel, then spray rustcheck on the rails,forks...wherever slidey things slide..... looks GREAT for 3-4 days, then...back to 'normal'
PC paint is a run around to avoid HUGE 'environmental' charges up here. Heck a gallon( well 3.78 Liters) of oil based paint is now $100 CDN.
JimmyJazz
1,248
778
Pittsburgh, Pa
Your time would be better spent taking your kids to the zoo.
nerwin
Nov 13, 2024
316
602
Vermont
youtube.com
I don't know if it's powder coated or not. I'll take some closer pictures. It's peeling like paint which made me think it's just painted. But it could be powder coated which will make things harder.
Is it difficult to repack the pins so they work smoothly?
I know how to use tools guys 😂
I got everything to rebuild...many grinders, cabinet full of abrasives, sand blaster, paint sprayer, etc.
I just want to stop the rust as these are quite expensive forks. Apparently these forks were purchased new back in 2022. They look older than that so I'm not sure. The tines are in good shape...it's just the frame that's a little rough. The previous owner definitely preferred this attachment, must've been his favorite haha.
5,420
my pins work fine when I lube them . Rustcheck is a kinda semithick oily spray that clings pretty good.The rails do need to be slippery for the forks to slide.
Mine is stored inside ,under the big worktable, so rain doesn't wash away the lube.
forks vs bucket is probably 50/50. They are GREAT !!!
sadly only real 'cure' is to remove 100% of the PC paint, then use a quality 'real' paint. Epoxy paint might be best IF you let it properly cure BEFORE you use the forks. The paint on the 'rails' where the forks slide will get scraped off ,no matter what you put on.
5,058
Use OSPHO before painting rusty steel
