Just loosen it, and I bet the arms will rotate.I was thinking about this and if I rotate one, then the bottom piece connecting both attachments won’t line up. If I do both, then it defeats the purpose and the gap will stay the same. This sucks. The bottom piece seems important in distributing the weight of the loader, I would have to modify this too.
do you think it will clear the bell housing? The notch is tight and not much room. But I’m willing to try.Just loosen it, and I bet the arms will rotate.![]()
Really sounding like you have a bad set of mounts?do you think it will clear the bell housing? The notch is tight and not much room. But I’m willing to try.
Good point. I will do thatReally sounding like you have a bad set of mounts?
Don't use the front axle as a reference point.
You need to use the front of the frame.
Don't measure to the pipe, measure to the mounting points.
