Fixing something to fix something.
7,325
Fixing something to fix something has been a very common theme for me over the years, and today was no exception.
I bought an aluminum CargoPro trailer eleven years ago to pull behind the Jeep. It's light at 400lb and is rated (GVWR) for 1,800lb so a good match for the Jeep. I installed a 7-pin trailer connector in the custom bumper of the Jeep around the time that I bought the trailer. A couple of years ago the spring loaded door broke off, and then the trailer end connector housing that came with the CargoPro broke, so it has been annoying to say the least to get the trailer connected. I kept putting it off since I figured it'd be a real pain to replace/pull the trailer end cable all the way back to the connection point at the other end of the tongue. I had purchased a replacement 7-pin trailer connector and a 7-pin silicon sheathed trailer end and cable at least two years ago, and possibly three years ago, but it sat in a box in the garage.
This morning I planned on going to the local landfill to drop off a bunch of trash, so got the aluminum trailer loaded up and ready to go. After filling up the trailer I set about trying to connect the broken trailer end to the broken trailer connector, and once again it was a pain to say the least. After messing with it for 15 minutes I finally told myself that enough is enough! Two hours later I had managed to remove the old trailer end and cable, removed the old trailer connector, run the new trailer end cable through the tongue, soldered the four necessary wires to the factory harness, covered the connections with heat shrink, tapped the four holes in the bumper to use a nicer hex head screw, and installed the new trailer connector. I tested the wiring before buttoning everything up and all is good.
So once again I had to fix something to fix something. I never got to go to the dump but that can wait until tomorrow. I'm pleased to have finally got this done and be outside on such a beautiful day.
NorthwoodsLife
Oct 15, 2021
1,082
1,032
Wisconsin
Looks good.
"Fixing something to fix something has been a very common theme for me over the years, and today was no exception." Yep. Story of my life.
Question: Why a 7 pin on a 1800 lb GVWR trailer. Does the trailer have brakes?
Seems like a 4 pin would suffice.
7,325
Looks good.
Good question and you're absolutely right. The trailer came new with a 7-pin connector but only four of the wires are used for the lights. There are no brakes on the trailer. Since the trailer was set up that way, I added a 7-pin connector to the Jeep and much prefer that style over the four pin connector type.
5,411
With 7 pins it's easy to add backup lights to trailer , add battery for winch on trailer.
Maybe one day he'll want brakes ?
You can have brakes and work lights on a 4 pin wiring though, costs about $40 + or - .
7,633
ALL of my trucks and trailers no matter how they are equipped use a 7 pin plug.
I got tired years ago of trying to find that lost / misplaced adapter!
biketopia
Feb 15, 2024
221
176
Warrenton VA
Exactly! I've converted every trailer I ever had that has a 4-way over to the 7-way. It's a more robust connection and has no adapter. None of my tow pigs are new enough to have the 7 & 4 way standard, even so, I'd convert over.
5,411
same here...every ONE ..
Both my ONE truck and ONE trailer are 7 pinners. Downsizing does have it's benefits though I do miss my 4pinned trailer with brakes and work lights.
7,325
Yep! I have five trailers and all have the 7-pin trailer end connector. The boat trailer has hydraulic brakes but all the rest have electric brakes with the exception of the CargoPro, so even if a trailer only needs a four wire connection I still much prefer the 7-pin style.
My '02 F-250 and the Jeep, and now the '24 F-450 have 7-pin connectors. The F-450 has an additional connector in the bed for the gooseneck/5th wheel which is nice.
7,325
You've often mentioned reverse lights on a trailer and I've "seen the light" so to speak. This is something that I'd like to add to all of my trailers at some point.
