Does my ZG327 really need a new engine?
tcwild
BX25D, ZG327
Jun 22, 2017
Pine Bush, NY
Bought used last summer with 900hrs, but it was in decent shape and ran great all season. Suddenly last week it started losing power under load, noticeably when engaging the blades, when getting to any length grass, and when attempting to move up hill, it would get sluggish to the point of stalling out. I replaced fuel filters and checked lines but I don't know much about small engine repair, so I took it into a dealer for service, they told me that a compression test on the engine showed 0 PSI on the right side (140 on the left) and that meant I needed a full engine/muffler/wiring harness replacement to the tune of $5000, which is more than I paid for the thing last year.
Just looking for some more knowledgable opinions on what I should do here. Worth it to find someone to do a rebuild cheaper? Scrap it and finance something new? I simply can't afford to buy a new one or pay that much in repairs right now.
3,653
I needed a full engine/muffler/wiring harness replacement ,,,,,,
This confuses me, why new muffler and wiring harness, and a rebuild aint gona cost 5K,, me thinkest , thou should get a second opinion
tcwild
BX25D, ZG327
Jun 22, 2017
Pine Bush, NY
The wiring harness was partially repaired at the beginning of the season, this may just be an additional fix, but to clarify, the labor for replacing all three was quoted at $1k, most of the cost was $3k for the replacement engine.
lilguy
166
11
Illinois
Get a second opinion. Why is there Zero compression in one cylinder? Had a Onan twin rebuilt years ago for less than new. It did cause me to go diesel next purchase and they have lasted 30 years compared to 5.
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
If you have good compression on 1 cylinder and 0 on other, I would dig just a little deeper for the culprit...I would find someone who is willing to chase the problem a little further before throwing up the white flag on a new engine.
William1
BX25D
Jul 28, 2015
1,145
346
Richmond, Virginia
A stuck lifter, bent valve, stuck ring or many other things can cause 0 compression. First, do a leak down test, that will tell you if it is rings or valves. If it is vales, remove the valve cover, spark plugs out and the engine turned over, watching the valve train. That will tell you if it is a bent valve, pushrod/lifter issue. A few hours of labor to fix. Rings, depends what it is. Most of the time, it is a stuck ring that required the piston to be removed, the ring land cleaned, the bore deglazed, new rings. Again, not even a days labor.
If the piston is damaged, rod bent or barrel heavily gouged, it is often cheaper to do a new engine. You'll of paid for diagnostic time on the old engine (four hours or so) four or five hours to swap engines and cost of a new engine. No good shop will just see 0 compression and say it needs a new engine.
Almost all these issues are a result of failing to run it regularly and not changing the oil often enough.
I run a Sears garden tractor, 1,000 hours on it and it still purrs like a kitten. The only failure I have had is the oil seal under the flywheel leaking, a one hour job. My 1981 Murray push mower from 1980 starts every spring on the first pull. Maintenance.
dholt53
11
Gasburg
I also have a zg 327. It’s a Briggs motor sold by Kubota . Is there anywere besides Kubota we’re I can get parts for this?
5,361
2,037
It is not a briggs engine. It's a kubota engine, as I remember it was designed by Robin (subaru). You get parts at the kubota place, nobody else sells them to my knowledge
0 compression could be anything but yes I'd want a second opinion
and yes they are real expensive to rebuild if you need a crank and a block, and sometimes they do
#1 cause of engine failure on that mower and also the ZG222/ZG227 (same engine) is overheating. Flywheel screen is buried down in a hole, nobody keeps it clean, it plugs with clippings and the engine is starved for cooling air leading to overheating and subsequent oil usage.
without knowing any better, it almost sounds like the OP bought someone else's problem. But that said, those engines are excelelnt engines so long as the screen is cleaned frequently, the air filter is kept clean and replaced often, and oil changed at or preferably before the interval. They'll run thousands of hours. Oh and a valve adjustment.
Speaking of which.....the camshaft on these cuts compression on one cylinder via a compression release. Only on one cylinder. So when doing a compression test, one side is always low and the other side is always high by nature. Zero is extremely low, and I'd want to know why. My guess is that it's either been hot, or the valves have never been checked and the pushrod(s) is off. Or both. But a second opinion is in order for sure, or at least a better explanation.
