Kubota l245dt engine upgrade after going swimming
Rumrunner439
Kubota l245dh, 1952 Ford 8n , JD 3038e
May 6, 2022
Gulfport ms
So yesterday the gf was drivng the tractor and she refuses to learn how to push a clutch in or use the throttle lever. I'm usually by her and try to talk her through everything as she drives. Of all days I stopped to fix a rut she made and next thing I know I hear screams and see my tractor drive straight into my small pond. She didn't push the clutch in, didn't shut down the throttle and didn't hit the shut off lever. She just hit the right brake yeeting it into the pond. Now it didn't spit a rod out of the block but it bent a rod. I took the exhaust off, turned it over w the decompression lever on and got the water out. Then fired it up shockingly it started but number 3 cyl just puffed white un-burned diesel. So I pulled the injectors and saw numb 3 piston didn't come up as high as the others. So what engines will fit in the same spot. It has a d1101 engine. I'd like to upgrade to maybe a 28hp engine. Here's the link to the video of it in the pond.
Sawdust&Shavings
Apr 25, 2023
55
Stafford, VA
Upgrade to a hydrostat 'cause she isn't using a clutch, so no need to fix it!!
I agree the clutch isn’t being used and a hydrostatic would be the best choice. My problem is, what was wrong with the steering wheel…why wasn’t it used?
7,254
There are too many parts involved in that set up to be able to change the engine to a different engine.
You need to rebuild what you have.
One of the biggest factors on these is that oil pan is part of the front axle so swapping it to another engine is not a viable option.
And lock the two brake pedals together.
Or just get her an HST to work around the place with.
If you want more HP out of it, get another tractor with more HP.
Rumrunner439
May 6, 2022
Gulfport ms
She said she tried to slow down by hitting the brake but she jammed on the right brake pedal which pretty much made it go right.
MOOTS
MX6000
Jun 27, 2019
2,000
2,354
Canton, Georgia
Is she ok? That’s all that really matters. Stuff like tractors can be fixed.
I giggled at the yeeted into the pond comment though.
Rumrunner439
May 6, 2022
Gulfport ms
I thought the d1302a was pretty much the same block design ?
7,254
It might be similar, there is variations in all these old engines, some obvious, so not so much.
If it did cross right over without issues, I don't think your not going to gain enough to validate the cost and work of doing the swap.
But hey your time your money have at it.
I personally would look at getting a tractor that had the HP already and a lot of other improvements to go with it.
Going rate for a good running D1302 is in the $4K range
woodman55
L6060HSTC, RTV 1100
May 15, 2022
962
769
canada
Even if you trade for a hydro, yours will be worth a lot more if it is in good order, than as it is now.
5,086
If you knew in advance that she didn't understand the workings of the tractor, then you are to blame for the accident. She shouldn't have been operating it under any conditions. Would you let her drive a car that she couldn't keep under control?
My wife almost died as a result of getting out of the car without shutting it off and got run over by her car. She may never drive again, but she has learned the lesson to shut the car off first before getting out if she ever gets to drive again. She used to eat raw cookie dough even though I warned her not to. She no longer does that because the last time, she got extremely sick as a result. Some only learn lessons the hard way. Some learn from others' mistakes, and some only learn from their own mistakes. Some have to make the same mistake more than once or twice before they learn. Some never learn.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
91
58
Lopez Island, WA
A friend's wife died when she was mowing their hilly terrain lawn alone and ended up in a pond and was pinned underwater by the tractor.
Do you have a overrunning clutch on the PTO? Geared tractors driving brush mowers keep going even when the clutch is depressed until the brakes/drag stop the mower blades.
Get a ROPS on that thing, while you're at it.
Rebuild that engine; you may get lucky enough that all you need is a new rod.
7,254
The L245 has a one way or overrunning clutch already in it.
1,527
You could probably rig up a lanyard on the shut off and attach it to her so if she stood up or held her hand up it would shut the tractor off. Not sure that would work if the hand thrott is set though, but I think it would.
But that is locking the barn door after the horse was stolen. She will probably never drive that tractor again.
Hope you and her are both okay!
