Greetings all! Long time member, but haven't been active for a while cause my machine just works so damn well!
Here's the deets:
2008 B7800
Started it yesterday with no issues, and it just died while idling. It has never done this before. WTF?
Try to start, gives me a good solid "click" when I turn the key.
Check all the usual suspects; PTO's are not engaged, fuses are all good, clutch engagement is good. Battery is fine, lights etc. are all powered. There's even fuel in it!!
As I keep trying various fixes, the "click" goes away when I turn the key on.
Enough. Go in for the night.
Today I come at it again, thinking I likely have a starter solenoid issue and plan to just jump the starter terminals to see if that does the trick.
Firstly, I try to just start it again, and she lights up right away!
Any thoughts on what issue this is likely to be? Starter / solenoid / ignition switch??
Many thanks,
Here's the deets:
2008 B7800
Many thanks,
