G1800 Should I buy?
Hugo Habicht
G1900
Jun 24, 2024
203
235
Ireland
Hi,
as far as I remember out of my head the G1800 front wheel rims are symmetrical and they have ball bearings both sides, 25mm inside diameter if I am not wrong.
Kind regards,
Hugo
p.s.: my left front wheel is leaking. Maybe we can swap one wheel, at least we have symmetrical front axles then again :ROFLMAO:
I had my tyre off already (what a job) and it is rim corrosion in my case. No point filling gunk in, corrosion removal and respraying has to be addressed at some stage and I don't want it to be messier than it is already. This is further down on my loooonnnng to do list :)
Chairwolf
Kubota G1800
Jan 19, 2025
14
Roanoke, VA
Hi,
Kind regards,
Hugo
I checked mine, and it's just dry rotted. The whole sidewall is leaking, so I ordered 2 new front tires (4-ply) and a set of tire spoons. I did get the rubber off the rim with flat screw drivers, but it was no fun! Rim is in good shape. I may go around the edge of the rim with a file and sand paper just to make sure there are no burrs before I install the new tire.
Hugo Habicht
G1900
Jun 24, 2024
203
235
Ireland
My, your rims look like an order of magnitude better than mine, mine are leaking at the rim... I also had a bit of fun getting the tyre off the rim despite having proper tyre levers. My tyre mounting machine does not handle 8" rims. But I think I will make adapters, I do not want to do that job by hand again.
Chairwolf
Kubota G1800
Jan 19, 2025
14
Roanoke, VA
I was able to get the tires off with 2 flat screwdrivers and a flat bar. I did order a set of tire spoons to use for the rest (dismounting the other tire and mounting the 2 new ones). After doing it once, I think it will be easier with the right tools.
