Long post, sorry in advance...
We got hit hard by Helene (SC/NC border) and I am still working on storm cleanup 4 months later. Lots of trees fell, which I have already chopped up, stacked or burned. The entire yard is littered with snapped twigs and branches hidden under leaves. Raking manually would take forever, so we opted to pick up the larger branches by hand and leave the rest. I swapped out blades on the mower deck to chew through the small twiggy stuff but it has been a slow process. Seriously my yard looks like all-bran cereal. Even where I have cleared the debris, the ground looks awful and is in desperate need of dethatching and top soil spreading.
We have an Agri-fab leaf vac that I have frankensteined to fit the BX2380, and it works fine for dry leaves, but add one small twig and it jams. Right now it is as good as useless.
1) Which implement(s) would you recommend for this type of cleanup? Some neighbors have lawn sweepers that seem to work nicely, but I have also considered getting a dethatching rake. We have more trees in our yard than everyone else around.
2) Helene washed away much of our top soil, so the ground is now uneven, rocky, and rattles my joints apart when I drive over it with the tractor. I have considered renting a top soil spreader, but I'm honestly not sure what direction to go. I've never had 2 acres of yard wash away before. Most areas only need 1" or so to even out. I can fill and flatten the larger dips and gulleys with the FEL/float. Other areas are far deeper and will require a few dump trucks worth of fill dirt before top soiling...
We were blessed that our home only suffered mostly cosmetic damage that I'll repair myself, but insurance and FEMA will cover nothing for us (and we have found it's the same for the vast majority of people around here).
I do not have the option of paying a company to come in and remediate due to scalpers. Everyone is scalping because they assume insurance is footing the bill. Big problem around here.
I'm nervous attempting to re-grade the yard with a box scrape as our entire yard is sloped with multiple terraces along the hillside, but I'm not opposed to getting one if that is the right tool for the job.
Any thoughts?
Any thoughts?
