Great tractor, good decision. I think you could go down to the L-60 series, but no reason to. MX is a good size machine, and better to be bigger than smaller.First let me thank you all for all the information. Really helped ramp up my education. Went and visited my local Kubota dealer and am looking at the MX6000. 4wd, HST for loader work, great rear pto HP, and a loader that has plenty of lift capacity.
The tractor is the thing you buy once. If you buy without a cab and want one, you have to sell the whole tractor and buy a new one. Do it once, do it right. Virginia gets cold and gets hot. Dad always loved his cab tractor (I have an open station). Mowing for 3 hours in a cab is a very different proposition from mowing open station. You can do everything you describe in an open station, but once you're thinking about a cab, just do it. When you drive in the woods, take a chainsaw or a polesaw. Anything that looks like it'll hit your cab, cut it off. Problem solved.Decision i am trying to settle now is Cab vs no cab (see advantages to both). Will be using this thing in VA, year round. Like the idea of heat during cold weather. And who is gonna complain about A/C. But the 10k bump in price and then additional "things that can now go wrong" just has me wondering if its worth it in the end. Yes i know i mentioned some work in the woods and the open cab was recommended for that reason. So perhaps I should stop second guessing and just take that as my sign to save the money and go that route.
Definitely focus on the bare tractor up front. If you're tight on money leave some implements for later. You can usually borrow or rent, and a lot of implements can be found way cheaper used if you keep your eyes open. I'd go without an implement for a year or two before I'd compromise on the tractor.Second thing is questioning attachments up front. Quoted quite a few, but all new attachments really jumps the total at the end. So thinking of just sticking with the front end loader, maybe grapple bucket, and post hole digger (looking at the hydraulic front mount option) to start. Leave the bush hog, pallet forks, blade, and such for down the road and possibly from the used market to save some money.
Front end loader: yes, obviously.
Grapple: you don't have to, you can do a lot without. Get the 3rd function, leave the grapple for later. Better if you can get it, but not essential.
Post hole digger: a hydraulic posthole digger is very expensive. Do you need it? Tractors (even an MX) don't have a lot of flow, it'll never go super well. What sort of posts are you putting in, what sort of soil? In my part of the world the pros have all gone away from post hole diggers, because you have to backfill and ram and screw around. They all have post drivers that go on the rear, stack up the posts, bang them in. No filling of holes, no screwing around. And actually way safer than an auger, those things are death traps. But if you must have an auger....just get a cheap one that goes on the back. They should be available used all over the place, they're the kind of thing people buy then don't use much. Often cheap at farm auctions (at least in my part of the world).
Bush hog: I'd be getting that way before a post hole digger. I guess depends how many posts you have to do, but if you can't mow then your tractor is pretty limited. Whereas post hole diggers you can easily rent for a day, or just hire out (doing fencing sucks anyway).
Pallet forks: cheap. Get them elsewhere, or second hand. No reason not to get them though given how cheap they are. And they can be a poor man's grapple.
Blade: depends what use you have. I don't have a blade, but I don't have a gravel driveway.
Live PTO I think means the PTO keeps going when you put the clutch in, so your implement doesn't stop running when you come to the end of a row. But that's really a manual transmission thing, I think all HSTs have a live PTO - the PTO and the transmission aren't directly linked in the same way they are in a manual tractor.Things i am thinking that i want to make sure the tractor absolutely has up front are 3rd function and dual rear remotes. Anything else? also someone mentioned to make sure it has a live pto. Not sure what that means?
Remotes and 3rd function are cheaper installed while they've got the tractor and doing prep. They'll also discount when you're buying in a way they won't later. But if you're keen to install them yourself, you may be able to save money that way. I feel like many places will sell them installed on a new tractor for about the same price as the parts would cost you later....in which case it's a no brainer.
