Tractor dies, then starts right back up?
Evad
L3301
Apr 2, 2022
51
20
Redmond, WA
This was a new one for me. I was grading our road like usual, engine at full temp and about 20 minutes into grading the tractor suddenly dies. Like somebody flipped an on/off switch. The entire dash when dark. Then 3-4 seconds later, the dash lit up again. I cranked the engine and it started right up. Drove it home and looked it over but don't see anything. Drove it for another 20 minutes with no issues.
Seems like something electrical tripped, shorted or lost connection. Any ideas what to look for?
Thank you!
5,245
1,029
Plse provide a picture of the top of your battery and another where the negative cable attaches to the engine or frame.
How old is your tractor and how many hours on it?
5,866
Sounds like maybe your OPS (operator presence switch) shut it off. were you leaning to a side when it shut off?
5,240
No... from the OP...... The entire dash when dark.
That means ALL power was lost. OPS will not do that.....just kill engine...
5,240
Not necessarily, depends on how it was designed and wired into the machine.
Will need to see wiring diagram as 'one size does NOT fit all'.....
One scenario... battery is fully charged, so alternator goes to 'sleep' ( NOT supplying any power ) ..battery ground cable opens, kills all power to tractor, engine shuts down. Have to remember there's usually a 'computer' involved and 'somehow' the alternator would have KNOW 'loss of battery' and then wakeup(takes time..), supply energy to it's field coils, all before engine stopped spinning.... classic 'chicken and egg' problem. I have designed many computer based products that run off AC with battery backup that need to keep some sections alive ( say Real Time Clock ). Those parts need to know 'no AC and to switch over to battery' and keep battery recharged, but not over charged.
As for 'cars', some now have the ECU control the alternator ! So the cheap alternator could be 100%, it's the $$$$$ ECU that needs replacing, grrrrr
Evad
L3301
Apr 2, 2022
51
20
Redmond, WA
Thanks for the responses. It's a 2018 3301, I bought it at 250 hours in 2021 and it now only has 370 hours on it. I am unclear if this is the original battery or not. Not much in the way of markings. They dont appear loose but could use a cleaning for sure, including the ground connection to the tractor.
MOOTS
MX6000
Jun 27, 2019
1,986
2,338
Canton, Georgia
I had the same thing happen to mine, driving and it was like someone shut the key off. Started right back up. Did some poking with meter and found one of those slow blow fuses (near over flow tank) loose in its holder. Bent the tabs a bit and hasn’t happened since.
7,076
Any break at the battery would not do this, the alternator would keep it going.
Like @MOOTS said, check the main fuses for a good connection.
The other option is a bad connection at the main switch.
5,245
1,029
AS a cheap first attempt, remove both battery cables and completely polish any metal surface including the ground to frame.
I have seen worse "top of battery" photos but certainly your could be better!
7,076
Dave, removing the battery cables while it's running will not cause it to die suddenly with no power to everything, Unless the alternator is completely shot.
