L3750DT Movement issues
trenn
L3750, BF900, L4540
Oct 25, 2022
15
Valatie,NY
Barely moves forward of aft ?
(*MOD EDIT: Title changed:)
8,029
One they never made a Hydrostatic in that model, it's just a gear drive tractor.
You have a fried clutch disk. 😉
8,029
Hydraulic shuttle shift is not hydrostatic ? I was thinking clutch. Now just have to figure out how to get to it.
No a hydraulic shuttle is not a Hydrostatic transmission.
They are completely different transmissions.
Does it act exactly the same forward and reverse?
If it does then it's unlikely that it has to do with the shuttle clutches and it has to do with the main travel clutch.
There is 2 possible main clutch types for that model, single disk and dual disk.
Let's figure out what clutch you have, that might help us troubleshoot further.
Look at this part of the clutch pedal and tell me what clutch pedal you have
Dual clutch pedal, note dual arms (yellow).
Single clutch pedal
Note single arm (green)
trenn
L3750, BF900, L4540
Oct 25, 2022
15
Valatie,NY
Green single arm .According to the parts manual shuttle shift has single disk clutch. Moves about the same forward and backward. Did have a clutch problem pushed clutch in one day and machine did not stop, put shift lever in neutral to stop. Found clutch way out of adjustment. Adjusted IAW manual worked fine. Happen again twice then worked correctly. now barely moves forward or backward, PTO works, backhoe can be moved.
8,029
The fact that you've had issues with the clutch pedal would point to mechanical clutch being the issue.
But, the PTO working as it should, is not pointing to the mechanical clutch, its pointing to the hydraulic shuttle clutch or the hydraulic shuttle valve.
Are you sure the PTO is working with force when you try to move the tractor?
trenn
L3750, BF900, L4540
Oct 25, 2022
15
Valatie,NY
Going to wait to finish trouble shooting till the weather warms up.
