One for the Wall of Shame
pigdoc
G1800S L2500
Aug 19, 2022
301
226
SE Pennsylvania
Hi guys,
Hadn't run the L2500 for months, so I was getting it ready for tomorrow's predicted 6 inches. Charged the battery, it started right up, ran for a few seconds, then quit. Tried a couple more times, same result. Figured it was the fuel filter.
Picked up a new fuel filter this morning, a Carquest 86390, made by Baldwin filters. (Cross-references to a WIX 33390) Spun the old filter off, and there was no leakage - line from the tank was clogged...with ice. Looked inside the old filter, it's about 90% full with a block of ice. 😝
I've owned this tractor for more than 2 years and haven't once looked at the fuel system before now. Shame, shame, shame...
I filled a 2-quart hand pump sprayer up with the hottest water I could get from the house tap and started irrigating. Pretty soon, I had a dribble of fuel at the filter connection. Spun on the new filter. Took the 1/8" rubber vent line off the injector pump and opened that air bleed valve. Let 'er run until I got a nice stream of clean fuel (no bubbles). Then, cracked the injector lines up top, and started cranking. Lots of cranking, lots of air bubbles. Finally got a weak stream with no air bubbles from #3, so I tightened them all down, and cranked her up. After she worked out all of the residual air, she settled down and ran smoothly. Ran it for about a half-hour to get things all warmed up and moving again.
When I get a nice day for some (outdoor) shop time, I'll change the fuel filter again, because it probably has more water in it again. And the rubber lines are hard as can be. I was afraid to touch them for fear of cracking them. All need replacing. Not sure yet where the water is getting in, but it could all be accumulated condensation as the tank level was low.
I'm just amazed that the tractor ran at all (before) with all that water in the filter.
That's what I get for leaving it outside, uncovered.
-Paul
pigdoc
G1800S L2500
Aug 19, 2022
301
226
SE Pennsylvania
Water, or gelled fuel?
Oh, it was water. Inside of the filter looked like the top of an ice cube. And, after I started irrigating with hot water, my catch bucket had a nice layer of water from the fuel line laying on the bottom of it, fuel floating on top.
It only took about a quart of hot water, streamed on the bottom of the fuel tank and its outlet nipple to start to break things loose. Little chunks of ice falling out of the filter adapter...
-P
pigdoc
G1800S L2500
Aug 19, 2022
301
226
SE Pennsylvania
Oh, and I haven't noticed an issue with diesel fuel gelling in this area until it gets below 10F. It was in the mid- to upper 20s today.
[Been driving a Cummins diesel for 20 years.]
-P
5,248
1st, HAPPY you got her up and running so easily !
2ND, I'd TOTALLY drain the fuel tank, flush,rinse, fill with FRESH fuel
this time you 'dodged the bullet'.... but next time ???
5,868
Paul, I have a friend who would take a fuel filter like you removed and put it in his shop near the stove (in the winter) and let the moisture evaporate, then reuse it. I n the summer he would just let it set out for couple of weeks. He never had trouble doing that, but I always teased him "he's tighter then bark on a tree!"
5,007
I have spare filters, just don't have the motivation to change them in freezing weather. If the tractor doesn't start, then I will default to G-d putting the snow there, he (she) can take it away. That is I why my cars are all 4-wheel drive.
5,078
My dad had the same snow removal theory, but we lived only 300 yards from the salt water,
