Wheel Spacers
Apple Farmer
Worley, ID
Looking for advice on what width of wheel spacers for my LX3310. My property is made up primarily of rolling hills. The implements I use are FEL, 5' box blade, 5' brush hog, 6' snow plow, and pallet forks. I'm thinking at least 2", but not more than 3". I am also going to get the tires filled. My previous tractor was a BX2660. I had 1 1/2" spacers on it and could feel the difference. The LX3310 has a cab and feels a bit tippy right now. I've had it for a little over a month. Appreciate any advice from those who have used spacers and/or filled tires.
mmlogan
LX3520, LA545, BH77, BB1260, FDR1660
Dec 9, 2024
9
South Carolina
Following this closely. I just bought a LX3520 Cab and I can't get past the pucker factor. Maybe it will come with time, but, I'd like to make it as safe as possible.
2,997
Using the search feature as as WI_H suggested certainly should tire you out reading all the posts on the subject.
One thing in your post caught my eye. Highlighted in blue above. In my case I finally got spacers for my B2910 last summer, and I can't feel the difference at all. I went with 4" rear spacers.
I think the reason is I tipped the tractor on its side once about ten or twelve years ago. Gun shy once, gun shy forever I suppose...
3,737
I went with 2" spacers from BroTek. Same machine as your minus the cab. https://bro-tek.com/products/view.php?&eid=60160997
Night and day difference.
I think my final width of rear tires is approx 58". Be careful going to wide with the spacers if you don't want to get out past your rear implements.
Mitjam
Jan 14, 2013
275
294
Edmonton, Alberta, Canada
I have used the search function. I cannot verify my bolt pattern as compared to those postings.
So I had an a lx3310 and now a lx3520 bolt pattern and hub are same so if you buy spacers for any Lx 10 or 20 series they will fit. I have 2.5” on mine helps a ton even that. Only thing to watch out for is if your have a mid mount mower dont believe their compatible. Mine are bro tek brand
mmlogan
Dec 9, 2024
9
South Carolina
Mitjam, I appreciate the help. That's what I needed to know, I ordered from Bro-tek. I had not considered the stick-out in relationship to my attachments. Thank you for pointing that out!
