That sounds great....thanks.Water sock.
And also treat the tank with a biocide.
How much water entered the drum?One of my storage drums got a dose in the last rainstorm....
Reading your equipment list the B5100, BX2200, G1800 will all be fine if you have any amount of water in the fuel.Thanks all for your replies, Ill try to save the fuel....if not then it will do OK in the home oil burner. Thanks again.
I grew up in the fueling selling business and have dealt with a lot of water in diesel. Its no fun and can cause a lot of issues. When you say a drum are we talking 55 gallons or less? If 55 gallons or less I would just like the water settle out drain off the water and I would take the diesel to someone that burns waste oil and let them burn it. I wouldn't chance it in my equipment or my home heating system. Its not worth the possible problems that could be caused.One of my storage drums got a dose in the last rainstorm....
For $20 you can get a product to protect your tank from water damage and it will also bond with the water so it can go through the burner and not cause problems. I had used it for over 30 years in my home heating oil tank. Many home heating dealers have a few bottles on the truck in case the customer asks.Pouring water laden fuel into your home heating tank is no smarter than pouring it into your tractor. Water in your home heating tank will cause the tank to rust from the inside out and can cause your burner to quit when you need it the most.
This is how I solved the water in the fuel issue.A fuel water filter.
That’s an option. I’ve never had an issue with water condensing in the tractor fuel tank. The storage tank is the primary issue for me, so I’d rather filter it out before it is pumped into the tractor.This is how I solved the water in the fuel issue.
