brandonvanbeek
Vendor Member
Kubota RTV
Mar 20, 2024
Hudson, South Dakota
Got ready for the snow this morning, they are threatening us with, supposed to get it tonight and tomorrow. We will see how much we get. I have three driveway to do this year mine, the tenants and the neighbors, her husband passed and he used to do ours when my parents owned the place.
Did you fabricate the mounts for the snow blade yourself? Do you have a closer picture?
It looks like it will do the job on some snow.
Siesta Sundance
Oct 23, 2022
1,789
2,496
youtube.com
Wow, looking at the field in the background no wonder that cow came over to check out the green scrub!!!! Your really are dry.
haha, 3rd year into this severe drought, and if 2025 repeats previous weather patters, no more livestock for me,
I'll convert everything over to wildlife.
I would have to look at the calendar notes to confurm, but I think we have received less than 2in of rain since July or late June!
Yes sir, we're slowly turning into a desert here. Very dusty here as well, all the filters have to be serviced every 10 hours as well with the grease zerk interval.
I would like to have this pasture/ or a few acres ready to plant some cereal rye. I can't disc it unless I know were going to get some rain/moisture. If I open the ground now, the soil will lose any moisture that's remotely left in it and lose surface sand/soil from wind erosion.
Sawburner
L2501, Gravely 526
Dec 18, 2022
71
183
NY
I like it.....matter of fact, I really like it !! Did you use a spray, brush, or roller?
Brush and I just dabbed it on, works better then brushing. I didn't take them off, paper and taped it.
Siesta Sundance
Oct 23, 2022
1,789
2,496
youtube.com
Limit was 20 gallons, Circle K day, for 3 hours they lower the price by 25 cents, plus 10cents by using the free discount cards. They give out these discount cards on Circle K Days that offers 10cent off per gallon, card last for 3 months. We picked up 2 cards.
GreX
BX2380
Jan 8, 2023
185
132
Maine
WOW - I just paid $4.59/gallon for diesel, even with your mentioned discounts, I would still be paying more than $4/gallon - and normal gas under $2/gallon!! I only use 93 octane (both my car and truck call for it), and I'm paying $4.79/gallon for that. Crazy!
6,565
Geez, I paid $4.39 for ethanol free today for my generator.
8 hours and 18 minutes run time since 3:30 AM. Restoration time TBD….
Quite a bit of heavy wet snow has caused about 30% of my county to be out of power.
Got to keep the Mrs. pies frozen…..
First time leaving the electric water heater on with this genny. Makes it snort a little when it heats, but seems to keep up with it. Tested it for a short time a while back.
Siesta Sundance
Oct 23, 2022
1,789
2,496
youtube.com
Set the pies outside wheres its cold!
6,565
That’d be great but it’s above freezing…..we’d have nothing more than a BIG F’n fruit salad with flour and shortening mixed in…..😳😳😉😉
She’s up to 93 pies now; same as last year.
All of them aren’t in that upright freezer but probably 60+ are.
She freezes them and sells them raw and frozen, or baked. She has a great system to bake them right out of the freezer. She gives her frozen customers directions to do that.
She’s self-taught after marrying a farm boy. Italians are not often known for pies…..
She’s gotten very good at it, enjoys making them and also likes the community projects she can help support. 👍👍
Reactions: 11 users
6,565
PS - know you’ve been terribly dry.
We’ve been dry just lately.
I really wish I could have sent you this. Got about annch of rain yesterday followed by varying amounts of snow depending on elevation.
We were about 4” in valley. Hills got 9-10”.
Either way was probably almost another inch equivalent.
Sawburner
L2501, Gravely 526
Dec 18, 2022
71
183
NY
Fabricated it. I need to redesign it some, I have to make a hinge where it is welded to the plate. I can't float it, the arms are to heavy and it digs in even with the shoes on the plow. But it works great for piling snow, don't have to dump it like with a bucket.
brandonvanbeek
Vendor Member
Kubota RTV
Mar 20, 2024
I was curious about it floating like on a pick up truck. I saw another one that used the attachment pins for the bottom, and a chain for the top to allow it to float like on a truck.
You can still manually angle the blade?
Sawburner
L2501, Gravely 526
Dec 18, 2022
71
183
NY
My plan is to make it work like it would on a truck and I can manually angle it.
g_man
Feb 3, 2023
219
991
NE Vermont
I made mine so the plow mounts like on a truck and floats with a chain. I set the push plate back under the SSQA plate to get the blade as close as possible to limit the side thrust when angled. More work and material but it works very good. Can even back drag with it.
Rust-Oleum overhaul
Back dragging. Can back drag with down pressure if desired too.
gg
Reactions: 7 users
Siesta Sundance
Oct 23, 2022
1,789
2,496
youtube.com
Spent over 8 hours in the SVL today. My body, back and arms are killing me. The hydraulic joy sticks will wear you out. I swear I need to wear a mouth guard at times, when those trees pop out of the ground it jolts you around in that 10k machine. The ground is hard as rock, even though the top layer is dusty as a mofo. I tried to have the air bag seat at the best setting for the bouncing. I started the day off opening up a 40ft section, clearing a heavy thick line of trees and brush along the fence line between our existing place and the new place we bought over the summer. The camera is near the fence and facing towards the house & shop that we bought in June. Only 1000ft x 50ft wide more trees/brush along fence to go.... lol
99% of all those trees and brush is invasive species to Sourh Texas.
Most of the day I pulled up all the small trees in front new 10 acre pasture. That pasture hasn't had any attention in years.
