I'm new to the tractor community and just picked up a 2022 L2501 HST. I have a long driveway, although it's all flat, no hills. For years now I been maintaining it with side by side by pulling a homemade grader that I add several cinder blocks on top for weight. I even welded metal rods to help break up the driveway. Its quite a chore to say the least, takes me literally all day and nearly 10 gallons of gas lol. I end up using my snowplow for it to be able to smooth it out after. But no matter what, few weeks later the potholes come back. I just can't get down enough to get under the potholes.
The tractor should help big time with this. Now I have a rather hard pack driveway. I use what they call driveway mix or "stay-mat" which I believe is like a mixture of slate rocks and crush rocks to have powder, its blue-ish stone. After a while of driving on it, the stuff packs to a smooth finish, I mean you can nearly squeal your tires on it.
There a lot of attachments out there, most common ones I find are the box blades, grading scrapers and grading blades. From what I researched so far, the easiest one is the grading scrapers and the most versatile is the box blades.
I also want to be able to use the implement for grading topsoil as well. I see pros and cons of each one and I don't know what would be best.
I'm going to go out on a limb and say a box blade will be best solution as I believe its easier to be able to crown the driveway by adjusting the side links over the grading scraper. The grader blade seems to be more affordable option but also has no way of breaking up the driveway either since there's no down pressure on the 3 point.
I was looking at the Land Pride BB1260 but I heard folks bending it with the L2501 so would the BB1560 be better for me?
I'm not set on getting a Land Pride either, I seen ones from County Line, Titan, Howes, etc. Like what would be the best bang for the buck?
Would 66" be better for the L2501?
Any help would be appreciated!! Thank you!
