I have a hydraulic top link that I would like to add a check valve to. Would one of these work?
You want a double pilot check valve for your cylinder like the one in the link below. @TheOldHokie can confirm but that's my understanding. The link has some good information on how it works.I have a hydraulic top link that I would like to add a check valve to. Would one of these work?
I only meant that it's the type of check valve you need, not that you should by that particular one. My apologies for the confusion.
Gotcha, that stuff is out of my area of expertise.I only meant that it's the type of check valve you need, not that you should by that particular one. My apologies for the confusion.
Either one will work but they do not mount directly on the top link itself. Do you already have the top link and how are you planning on installing the check valve?I have a hydraulic top link that I would like to add a check valve to. Would one of these work?
