Ballast for LX3310
Apple Farmer
Worley, ID
New to the forum. I ran a BX2660 for several years and I had rear wheel spacers and wheel weights on it and it was quite stable. I have just bought an LX3310. I needed a little larger tractor or I possibly just wanted a larger tractor. The wheels on the LX do not have holes to mount weights, but I could install spacers and have the tires filled. I have heard that the cabs can make a tractor a little more tippy and my property is a little hilly. How wide of spacers to actually be effective and should all four tires be filled or only the rear? Any advice would be appreciated.
6,231
Are you going to be running a MMM on it?
If not the widest you want to go is your choice.
Filling the ears are the only thing that helps stability.
