Kubota BX 25 Want to add a thumb to BT601 Backhoe, Looking for advice.
06B3030
Sep 21, 2015
169
226
MA
The BXpanded thumb might be OK on a BX series tractor. I looked at the BXpanded thumb for a B Series tractor, and was just about to pull the trigger until I found this video. I have a B3030 with a BH75 and installed the Kubota manual thumb. I had to fabricate the dipper arm mount because the BH75 doesn't have one. The Kubota thumb is really nice.
Joe.G
BX25 W/601
Oct 13, 2024
34
9
NY
So I ended up ordering this one today, The Amazon one seemed to be hit ot miss with fitment and I don't really want to weld it on.
Joe.G
BX25 W/601
Oct 13, 2024
34
9
NY
06B3030
I don't know how I missed your post until after I ordered it. I watched the video and I hope I don't have those issues, I also don't think Kubota's is for the BT 601 Backhoe I believe its for the new version.
Mark_BX25D
Bx25D
Jul 19, 2020
1,744
1,262
06B3030
I came to the same conclusion when I researched it.
Please let us know how your new purchase works out for you! Pics or it didn't happen! :D
06B3030
Sep 21, 2015
169
226
MA
06B3030
Hopefully the thumb on the BX will hold up fine for you! I think they just made some "length" adjustments to make the BX thumb fit the B series, and didn't take the added hydro pressures into account.
Old Machinist
May 27, 2024
102
110
NE FL
Understand that any add on thumb is capable of applying full digging force to an area of the crowd arm that wasn't designed to take it.
That said they are extremely useful. I put a Titan weld on thumb on my full size backhoe and just broke it after 8 years. My welds held up okay but it ripped the metal open on the crowd arm. I should have reinforced the crowd arm which I will do after repairs. I have to cut the thumb off and straighten and weld up the arm metal first. This machine has over 10,000 lbs of digging force though.
Tractor Gal
BX23D MLB
Oct 30, 2020
470
131
NC
Joe, I think you made a good choice with the BXpanded thumb. I purchased one for my BX23D and have really found it useful. I use it to pick up and carry logs and rocks, hold longer logs off the ground while using the chain saw, pull vines out of trees, et. While having an hydraulic one would be great, unless you're going to be using it a lot, the manual ought to work fine. You'll get the hang of making the adjustment to fit the project.
As stated above, report back with your experience when you have had time to give it a real whirl.
Tractor Gal
