M8560, parked regen in a loop.
m8560gilroy
m8560
Nov 3, 2024
Gilroy
Hi, Immediately stopped the tractor after the parked regen light flashed. Started the regen process and it completed after 35 minutes and the lights are not turning off. The one second beep started and I started the regen process again, it is back to beeping and begging for the parked regen again, Need advice
5,189
1,874
beep every one second usually means that the dpf is pretty well plugged. Sometimes a regen will fix it, other times not, and based on what I'm reading in the post it sounds like it's plugged to the point where regen cannot complete properly. Probably have to pull the DPF off and have it baked out. Then reinstall and have dealer reset the ECU.
m8560gilroy
m8560
Nov 3, 2024
Gilroy
Thank you
