Hey there. I’m new here but did do a bunch of searching and didn’t see the answer for my situation.
Have a B6100 with the D650.
Engine runs but doesn’t idle well and pours out white sweet smelling smoke. Pretty sure the rear cylinder is dead. When I crack the injector line there’s no change in running but the white smoke goes away.
I did a compression check and got the rear cylinder at only 200 psi.
I added about a cap full of oil and compression only went up to around 220-230 psi. Normally I’d suspect something else like valve/head/gasket issues. But is it possible the rings/cylinder are so worn even added oil won’t improve compression much? Is there a procedure to rule in or out the head side components?
The other two cylinders aren’t great (~340 psi) but they fire.
