Sloppy steering stick
Gcoffman
ZD21
Oct 13, 2024
Alabama
hello, I have a ZD21, just started having issues, right side steering stick has resistance like it supposed to in till it reaches the point you are able to push to go forward or pull to back up, right stick is loose/sloppy when fully pulled in
Thanks
Gcoffman
ZD21
Oct 13, 2024
Alabama
I will check damper but is there a damper on both sides, just clarifying, I was calling the right side by sitting in the seat and on the right side where levers are located
Thanks for your help
Gcoffman
ZD21
Oct 13, 2024
Alabama
Yea, you posted the right side, I was looking at it wrong , I’m still going to check but the sloppiness is on the in and out , fully closed and up to probably 5” pulling levers back out
MOOTS
MX6000
Jun 27, 2019
1,920
2,193
Canton, Georgia
I would check bolt #80 in that diagram. Betting the right side is proper, and left is binding/too tight. Spray some lube on them and tighten so they still move but aren’t floppy.
