Using loader block for a rear attachment
xoxoxo
mx5400
Oct 10, 2024
Ms
can I unplug the curl port on my loader block an plug in the hose from my pull type cutter?
4,423
Yes, just trying to raise and lower a pull type bush hog.
If its a single qcting cylinder (one hose) you should connect the unused bucket port to the hydraulic tank. If you dont connect the extra port you wil run the pump against the over pressure relief valve evrery time you retract the cylinder. That wont kill the hydraulic system but should be avoided if possible.
xoxoxo
mx5400
Oct 10, 2024
Ms
Okay, I'm a little ignorant on this, so please break that down for me. i don't understand connecting the unused port to the hydraulic tank.
4,423
The loader valve hasvtwo bucket outlets.
You will connect the implement hose to one of the outlets
You need to get a another hose and connect it to the other outlet. Then run that hose to any place on the tractor thst dumps into the transmission.
xoxoxo
mx5400
Oct 10, 2024
Ms
I have since been told i can run the cylinder off 1 hose that pushes and vent the other end of the cylinder. going to try that before i do anything else.
4,423
You dont understand. You need to do both.
You must vent the unused end of the cylinder to use it in a SA application.
That does nothing to prevent overpressuring the unused outlet port on the valve. Connecting it to tank does.
That said, if the cylinder has two ports I would use it in both directions ( two hoses connected to both outlets) and there is no need to worry about any of the other issues.
Dsn
