M95 electrical problem
OakWarrenFarm
M95SDS
Oct 8, 2024
I have a M95 cab tractor, put a new starter on it about 6 weeks ago. Finished up fall hay no problems. Now when I turn the ignition switch on, dash lights come on but as soon as I try to start the tractor, I hear a click in dash area and all dash lights go out and tractor will not turn over. Replaced switch but still have same problem. I am getting 12 volts to the switch. Any ideas where to look next?
4,744
How old, corroded are the primary battery cables ?
When were they last removed, cleaned ?
when lights come on then go dark when starting , it's a sure sign that not enough current if flowing.
usually due to old or corroded cables .bad grounds, bad connections, bad battery
OakWarrenFarm
M95SDS
Oct 8, 2024
Battery and both cable ends were replaced back in June. Multimeter is showing 12.3 volts at battery and starter. When light go out on dash they will not come back on unless I wait about 30 minutes to try again.
1,285
Are you saying “clamp on cable ends” were replaced? Like these?
In any case really, please just go ahead and clean all the battery cable ends (four total). I would replace the cables if you have the clamp on ends. There have been MANY MANY cases where the poster says “cables were cleaned a month ago” that end up being resolved when the cable ends are all cleaned and tightly connected again. Sometimes that takes weeks to get back to so it is better to eliminate that first.
