I think I must have hooked a Boone & Crocket potato today. The fuzzy one inspected the handy work.
Don't antennae typically work better with a good solid ground for the mast? Normally did for me back in the day. Rubber tires aren't very good grounds, but perhaps you have something I can't see for grounding the antennae?Had to pop the top (canopy) off so spousal unit could use the MX as a mobile communications platform.
Well, your not wrong, but the MX is so capable that it’s it defies conventional wisdom in a pinch. .Don't antennae typically work better with a good solid ground for the mast? Normally did for me back in the day. Rubber tires aren't very good grounds, but perhaps you have something I can't see for grounding the antennae?
My job was bigger than rabbit ears. I had to go outside and twist the pole to get one of the three channels we could receive. Had to turn it a little east for the ABC station (Pensacola), but NBC and CBS (Mobile) were pretty much due south. Messed with my folks one time and pointed it at Meridian (Northwest). Hated winter nights when it got windy and raining, and I had to go out and move the antenna because the wind blew it around. I'll give you three guesses what normally happened before I got back in the house, but my stepfather wouldn't let me drill the pole and put something next to it to stop it from rotating by itself. I think he just enjoyed making me go outside in foul weather.Well, your not wrong, but the MX is so capable that it’s it defies conventional wisdom in a pinch. .
We use the TV / temporary antennae so rarely we only do this set up for whatever it is the spousal unit ‘has’ to watch. (I don’t plan to permanently mount it or buy a real tower or antennae that rotates. I just move the tractor until we find the channel.
When I was a kid I had the job of wiggling the rabbit ears…I adapted the concept with 60hp
Hurricane Milton could become a cat 5 storm, hopefully folks heed all the warnings. Pack up the Oranges and get out of the path.About a week out from another hurricane forming in the gulf.
