BXpanded ?
Bearcatrp
Mar 28, 2023
524
272
Minnesota
These folks good to go ordering stuff? With other companies dying off, want to make sure I don't get ripped off. Looking at this one. Thanks
4,728
I've never dealt with them but....
hmm 6' wide blade in front of an 18HP tractor just doesn't seem 'right' to me. you'll also need a fair amount of weight out back and chains.
JasonW
270
121
Al
I’ve used them several times. Although the hurricane just came though their area, not sure if they were affected or not.
JimDeL
Aug 31, 2022
280
291
Austintown, Ohio
I've bought several things from them. Always good service - and always have arrived earlier than promised.
Bearcatrp
Mar 28, 2023
524
272
Minnesota
I will have my 6 foot 3 point blade on the back. Would actually want a UTV blade up front as those are lighter. I put on R4's in the winter with no problems moving around on snow. Just want a front blade so all I have to do is one pass instead 2. I take care of our neighbors driveways as they are a older couple. Don't charge them anything. Great neighbors.
Thanks for all the replies folks. Still considering other options.
Bearcatrp
Mar 28, 2023
524
272
Minnesota
Am considering this one. Not as large as I want it but can take the forks off and use the hitch portion to mount up front. Plan is to only use this in heavy snow and leave it about 2 inches off the ground to clear most of the front. Then let the rear blade to the rest.
Here is the forks I have with the hitch to use.
One thing to add. I turn my blade backwards so I don't rip up the ground. Just tilt the blade so its almost straight down at a 45 degree angle. Works good.
4,802
Dealt with them several times years ago. No problems at all. Great products.
Don’t know their location but as mentioned in post #4, sounds like they might have been disrupted by the hurricane.
Certainly hope not.
Bearcatrp
Mar 28, 2023
524
272
Minnesota
Decided to try the blade from heavy hitch. If it doesn't work like I want it to, then back to the drawing board. Should help clear my front since my 1880 is 48 inches wide or so. Now watch, wont get any snow to test this out.
4,802
Certainly hope not.
Just found their location is Knoxville, Tennessee. Looks like some of the area East of Knoxville was impacted greatly.
Hopefully BxPanded and their folks escaped the storm safely.
