Good day.I have a BX2380 and use it some almost daily. If something happened to it I'd get a current version in a heartbeat to replace it. I use it to mow the lawn and haul stuff in the dump trailer.
I also have an old (55+ years) utility tractor that has seen better days. If I replace it I need something for mowing my 14 acres of fields and doing some other work where I need a front loader.
Any suggestions? Should I stick with another Kubota or get some other make?
Thanks.
Depending on how long you want it to take to mow and how much you want to spend (those two may not match) that might help suggest some options. I think from what others have said you have some good info already, but if more specific on your criteria may get some other responses (maybe).
How long do you want it to take when you mow? Without that piece of info there is a pretty big range of options that will do what you are asking.
Is there a price cap?
I think after asking those two questions maybe find where they collide or come closest to each other. (If you have a lift capacity in mind that would be helpful to narrow down choices as well)
Good luck.
