M4030SU problem with PTO Clutch
Cajun337
M4030SU, B1750
Sep 11, 2024
Louisiana
Hi,
When I mowed yesterday I discovered that the PTO was still turning/mowing when I tried to disengage it via the PTO Clutch Lever. I can’t find any procedure for troubleshooting or adjusting it in my binder of Workshop Manuals. Any help is appreciated.
Thank you
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
639
252
Herald Calif.
You would adjust the PTO clutch lever much the same as you would adjust the main clutch foot pedal. Should have roughly an inch to an inch and a half free play when raising the lever. Free play will be the movement of the handle before it begins to get tight. You have a threaded rod that you will link them or shorten to achieve that. You also have an inspection cover on the right side that you can look at the bearing touching the clutch fingers. The main thing to be sure when you're adjusting the clutch is at when it is in the engaged position that the bearing is not riding on the clutch fingers. Biggest problem I have found with these hand PTO clutch levers is that people tend to pull them up to disengage the clutch and leave them there. This is just like riding the main clutch with your foot. You want to disengage the PTO with the hand lever when you're finished take the PTO out of gear and return the lever to the down position. Great old machine.
Cajun337
M4030SU, B1750
Sep 11, 2024
Louisiana
Thank you for the help! I didn’t know about the proper use of the PTO Clutch Lever. I’m sure that’s why it quit working. I hope I didn’t ruin it. I hope I can adjust it back to functioning properly.
Cajun337
M4030SU, B1750
Sep 11, 2024
Louisiana
007kubotaguy
Dec 23, 2012
639
252
Herald Calif.
The throwout bearing has froze up and burn the fingers off the clutch. You will need to split the machine and replace the clutch. This is probably a result of running with the clutch lever up thus disengaging the PTO all the time. As I mentioned earlier in the future bring the clutch handle up when you're finished using the PTO and take the PTO shift lever out of gear and put the handle back down so the bearing does not turn all the time.
Cajun337
M4030SU, B1750
Sep 11, 2024
Louisiana
Thank you for your help!! A hard lesson learned…
