Kubota 7100 (Non-HST) not charging battery
newshb_k
Jordan
Hi All,
I have Kubota B7100 (non-HST) which is not charging battery. I have troubleshooted as below:
1. Checked the output voltage of the alternator, and it ranges from 12.4V to ~26V (based on throttle). The alternator is 2 wire Alternator
2. Verified that this voltage is the same as the input to the voltage regulator. (i.e. tested the two cables ends coming from harness (which is connected to the alternator on the other end).
3. Tested the voltage output of the regulator, (red and black wires) and it is 12.4V when idle, and then start dropping when increasing throttle. It never reaches more than 12.4V.
I though it could be bad regulator, so I purchased a new one Regulator, I hooked it up, and it is still the same behavior.
Any ideas what could be wrong.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
665
272
Herald Calif.
Be sure your new regulator is bolted down and grounded. Many times people replace them and don't bolt it down during the troubleshooting process.
newshb_k
Jordan
I have it bolted, and assured it is grounded. I even connected its black cable to the negative terminal of the battery
8,371
Did you test the voltage on the dynamo in AC?
5,559
hmm, can you charge the battery from a regular battery charger, while sitting on the workbench ???
A 'bad' battery can 'load down' the rect/reg unit giving the false impression the rect/reg is bad.
newshb_k
Jordan
Yes, and as mentioned, it varies from 12.4 to ~26
I measured the output directly from the regulator (I disconnected the red wire of the regulator and tested output from there)
The battery voltage is 11.98V
newshb_k
Jordan
UPDATE: I found out a loose wire (the one going from the motor to the +ve battery, once tightened, it started charging battery.
