New Member: Knowledge needed on M6040, 7040 (or others)
Jeeper1014
Twin Cities, MN
Hi all, new member and first time poster here. Early next year we will be moving to rural Minnesota on property owned by my wife's family. It is mostly woods, some open fields and almost no pasture. The property was a small working dairy farm in the past, and with it came the current tractor they have used over the years, a tired John Deere 1010 with limited capability.
To help us with taking care of the property, I would like to acquire a used, pre-emission, lower hour Kubota. I'm leaning toward a M6040 or M7040 as a good fit for all of our needs but am open to other model suggestions as well. I already know this will be an expensive proposition based on my lurking on here, but we have the financial means and given that we also have time before the move, I feel confident I can find the right machine when it comes up for sale.
Intended uses of this machine would be a loader for moving dirt and gravel, forks and I know my in-laws have requested a grappler attachment to help move downed trees and brush. I would also like to get a rear-mounted snow blower for clearing the driveway as it is about a 1/4 mile long. They have a PTO driven deck mower they have used with the Deere in the past that could be used on this machine as well.
Basically looking for anything that could be a a weak point, or must be checked on these machines that may not be as obvious with a visual inspection or while operating the machine. Any tips, tricks, buyers guides, cheat sheets or what have would be greatly appreciated.
Thanks in advance, Jeeper
PaulL
2,414
1,344
NZ
I'd be surprised if a mower from a JD 1010 (a 30hp machine, give or take) is right sized for an M6040 or 7040 (60 or 70 hp). It'll work for a while, but better to go bigger.
The M is a good solid machine. Minnesota is cold country - a cab needed? Would you blow or plow? A lot of people seem to recommend plowing if you have a machine that could do it, specially on a gravel driveway. If you get a rear mounted blower look at one that pulls forward (you drive over the snow before blowing it). Easier on your neck.
6,249
Those are both very solid and non problematic models.
SDT
multiple and various
Apr 15, 2018
3,247
1,034
SE, IN
Both models are well regarded but neither are pre-emission.
mcmxi
6,156
NW Montana
That's what I was thinking. Good tractors though regardless.
2,795
1,516
You should be aware that there are two basic transmissions available, synchro shuttle and hydraulic shuttle. The hydraulic shuttle is more desirable.
JasonW
293
135
Al
They are listed as Tier 2 which has EGR. But do not have a DPF, most I have seen talk about pre emissions are referring to pre DPF,DEF. Maybe that what he’s referring to.
Just be aware the M6040 and M7040’s last year was 2014. So at the newest they will already be 10 years old. If you don’t mind use IMO they are the best value for their HP/capacity.
JimmyJazz
1,212
734
Pittsburgh, Pa
How many acres are we talking about here?
SDT
Apr 15, 2018
3,247
1,034
SE, IN
Agreed.
I misread the OPs post, believing he was speaking of M6060 and M7060.
