Hello! I am a new owner of an older F3680 with 1500 hours on the unit. I am having an issue lately where the mower will shut off after mowing for a bit. It seems to be random and it will start right back up and can mow again. It is frustrating! It does not act like it is running out of fuel and have checked the fuel pump, filters, etc. It shuts off immediately like you turned the key off.
I initially thought that the engine stop solenoid was going bad, so I replaced it and it did not help. It doesn't appear to be overheating (and shutting down due to that). I am running out of ideas. Is there a controller or relay that could be going bad on this unit that could be causing this?
Thanks so much for your help! This is my first post, so go easy on me!
Chris
Chris
