How much did you pay for that 66704-88530 flange?Hey guys, just wanted to give an update.
I've had the Westendorf TA55 frontloader on there for a while now with no problems! I've got ~25 hrs of heavy front loader work with no issues.
I ended up fabricating a pump shaft using the female spline of flange 66704-88530 to 3/4" keyway stock and a Lovejoy coupling for the engine-to-pump connection. Pump is a NorTrac CBS6-F6. 3SS.
I built pump mount in cad and had Send Cut Send cut the steel and welded it up in place.
Hydraulic tank is an old steel scuba tank that I modified using parts cut by Send Cut Send.
I have cad for the pump mount if anyone would like it. I attached some pics for reference.
Thanks again for all the help.
