Are wheel weights necessary for “typical” work?
WigglyPiggly
MX6000
Sep 3, 2024
I have an MX6000 with R14 tires set to 70.5” width that are filled with Rimguard.
Would 2 sets of wheel weights per side (420lbs total) make a substantial difference in operation for loader and grapple work?
2,392
The real answer .......... yes there WILL be a difference ............. BUT the ease of placement on and off will be a real PITA.
I ballast box will do the same and do it better!!! Why - because now you are way behind the pivot point of the tractor, every inch you move reward you gain a tremendous mechanical advantage!
And taking the BB off is a lot easier too!
SDT
multiple and various
Apr 15, 2018
3,163
994
SE, IN
Considering the Rimguard, you will likely not notice an additional 420 Lbs. of cast weight.
A counterweight would be much more effective.
windy city
Jul 3, 2022
I also have an MX6000 with filled tires. When attempting to pick something over capacity the hydraulics for the loader limit out long before I see counterbalance issues.
WigglyPiggly
MX6000
Sep 3, 2024
I have a 1400lb ballast box I use when needed. This is more for everyday tasks when I have have another implement on the 3pt.
