2005 Kubota BX1500
MVB2018max
ZB1600DT
Mar 13, 2018
Walterville, OR
I just got this tractor yesterday, it worked great. I love this tractor. Today it will not work, no power. The battery and fuses are good. It will not turn over, no dash lights. ZERO Does anyone have any ideas of what could be wrong? Thanks for any help you can give
2,439
Wull
Tractor
Mar 21, 2023
72
14
Scotland
Have you checked the main fuse? If that checks out ok I’d be looking at the ignition switch if nothing is happening when turning the key, remove and check for supply voltage and whether or not the switch is working as it should.
4,957
[/QUOT]
"battery and fuses are good"
Have you actually LOAD TESTED the battery?
JimDeL
Aug 31, 2022
279
291
Austintown, Ohio
Two possibilities:
1. Dead Battery - Try turning on the headlights. Do they illuminate at all? If not, dead battery likely.
2. (Less Likely) the slow-blow fuse has blown. It's less likely because everything worked great yesterday. It takes pretty much a dead short to blow it, and usually other, smaller, fuses will blow first.
MVB2018max
ZB1600DT
Mar 13, 2018
Walterville, OR
Thank you for all of your help. My son was able to figure it out with your help. Thanks
