Sight Glass Fell into Rear End
4,558
Buy another white thing and start over again. If it is plastic or rubber, it shouldn't do much harm.
bronccat
M5700 4WD Hydro Shuttle
Sep 12, 2016
29
bardstown, ky
Thanks all. This was the white disc on the back of the lens that helps with visibility. Thin plastic. I assumed not a big deal, but wanted to make sure.
mcmxi
5,661
NW Montana
Hmmm .... here's the sight glass on the MX6000 open station that I sold, but it's the same as the one on the MX6000HSTC that replaced it. The M6060 has a dip stick.
5,789
I have the new one in, was going to add fluid and see of it floats up before adding silicone.
If it does, run to your nearest lottery retailer and Buy a ticket, because you are probably the luckiest man alive.
