Finally got piston out.cant find the connecting rod bearing.does it look like still in cap?didn't seem like any in caps.
It this point it really wont matter. Motor has to come out or box it up and send it down the road. Its toast.. no fixing it in Tractor. Well maybe a patch job to run a 1/2 hour even thats doubtfulTry holding the cap back on the journal and see how much gap you have. With no bearing it should be almost a 1/4 inch. If only a bit, then the bearings are bonded to the crank.
That's just it.the journals have no grooves or anything.they look good.It this point it really wont matter. Motor has to come out or box it up and send it down the road. Its toast.. no fixing it in Tractor. Well maybe a patch job to run a 1/2 hour even thats doubtful
Sorry wishful thinking. If it ran 1 min its done if no bearings. I saw this all the time with customers thinking it would be a cheap fix when a rod or main spun…. It aint its a complete rebuild. Unless the rod fairy came in the middle of the night and removed bearings. The rod cap clearly shows evidence of rod bearing tangs at one time and looks like it spun. No crosshatch marks on rod and cap were it was sized.That's just it.the journals have no grooves or anything.they look good.
And......he will spray it with gasoline first!Send it to joesmith he'll polish it right up.
AbsolutelyAnd......he will spray it with gasoline first!
Absolutelyi find it hard to believe that the engine ran without bearings in the rod. It would have rattled so bad that nobody in their right mind would even bother trying to buy it, or continue running it. And, the crankshaft would be all chewed up in about 1 minute, and it would have low compression (piston won't go all the way to tdc without a rod bearing)
my guess is that the bearing is stuck on the journal. I've done this and it's not always obvious. That or they fell out while removing. Can you get a picture of the crank journal?
