Pulled the the head off.the cylinders all look good.but I noticed on the head a triangle shape wear the piston hit.wasnt able to remove pistons yet.what all would cause this to look for?
pictures?Pulled the the head off.the cylinders all look good.but I noticed on the head a triangle shape wear the piston hit.wasnt able to remove pistons yet.what all would cause this to look for?
Rod bearing going or wrist pin bad . If no noise but could be bad crank also. All guesses. Either way its bad. How far in the hole at TDC are the other pistons?Pulled the the head off.the cylinders all look good.but I noticed on the head a triangle shape wear the piston hit.wasnt able to remove pistons yet.what all would cause this to look for?
All other pistons are good.on number cylinder the top of piston just barely put a triangle imprint.no metel is gone.Rod bearing going or wrist pin bad . If no noise but could be bad crank also. All guesses. Either way its bad. How far in the hole at TDC are the other pistons?
This is something that destroys engines in numbers second only to overheating so I think the more we understand about the whys and how's, the fewer will fall victim.or excessive carbon buildup on the piston's crown
ain't much clearance between the head and the piston normally, and this is exactly why starting fluid (and other "starting aids") often kills these engines.
I got the piston and rod out.the rod has a 6 on it and cap a 1.and on bother has a part number 9775.iv looked and no rod for a D1503 motor has that number.also my guess the number 6 on the rod.ment that went in number 6 cylinder.mine is only 3 cylinder.does Kubota even make a 6 cylinder? Nothing is adding up on that.pictures?
Sounds like a patch job to sell it. Were did you buy it?I got the piston and rod out.the rod has a 6 on it and cap a 1.and on bother has a part number 9775.iv looked and no rod for a D1503 motor has that number.also my guess the number 6 on the rod.ment that went in number 6 cylinder.mine is only 3 cylinder.does Kubota even make a 6 cylinder? Nothing is adding up on that.
No, they do not stamp the rod position on them.my guess the number 6 on the rod.ment that went in number 6 cylinder.
Yes, Kubota does.does Kubota even make a 6 cylinder?
