Attachment storage
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
38
22
Minnesota
I'm starting to collect quite a few implements and wondering how you guys are storing them. I don't like the idea of leaving them outside in the elements.
I could build a traditional rectangular (pole) shed but I know how that works; the attachment you want is all the way in the back and you pretty much haver to empty the building to get what you want.
I'm thinking open sided racking that would store 3 point items down low and FEL items on shelf above.
Would only cover roof, back and side walls. It would keep them out of the sun and majority of weather.
What are you guys doing?
4,693
Your idea, is the same that many do use.
old and tired
L2800 HST; 2005; R4
Depends on which ones, the ones that were cheap and were bought from people that had them in the open, they stall in the open. 6' Box blade/200, 7' rake/50, 6' rear blade/50, 5' cultipacker/150, 6' cultivator/75, 5' spike aerator/100, 2' sidewinder mower/50, and forks/free. These just hang out by the tree line, some you can't even see.
The most expensive one, Chipper/1500 stays in the small barn with the tractor. Along with anything small that can "walk" away.
The rest that I care and use more often, they live under our covered porch, 6' Finishing Mower/750, 5' mower/shreader/250, chemical sprayer/free, and the leaf blower/free.
Then odds and ends, are in the basement, PHD/400, hay bale spear/125, and other miscellaneous stuff are inside there, too.
