Backhoe subframe lx2620
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
Hi Ali , I’m looking to find the part number for the backhoe sub frame for the lx2620 . I’m not sure how to navigate the kubota website for parts or accessories . Thanks for the great welcome to the forum . That’s the first granddaughter on the new tractor . She loves it . The in-laws gave her a kubota tractor farm toy set and it was all she played with . My b series made the small town news with my son riding with me years ago working in the yard , course these days I might get arrested for abuse with him on it ?? Anyways thanks for the help . Enjoying the forum
nbryan
Jan 3, 2019
1,224
761
Hadashville, Manitoba, Canada
Here's a screenshot of the kubota canada parts finder, for the BH77, under options there's 2 sub frame listings. Each frame listed has 2 parts, the second being the hydraulic power takeoff kit.
You'll see the LX2620 listed for each frame set. I have no idea what's the difference, or which may fit your unit.
S-G-R
LX3310
Jun 17, 2020
1,079
2,191
PEI Canada
One may be cab specific. I think the sub frame is longer because of the extra seat
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
I was asking my son , he has the l3902 and his has a separate seat ( bh77 backhoe ) I thought mine would be the seat bracket included in the kit for swivel . It would be nice if they gave a parts list and diagram on the website .
nbryan
Jan 3, 2019
1,224
761
You can access kubota.ca via a vpn, using a Canada server, if a vpn is available. kubota.ca parts finder has exploded parts diagrams for all of this, as I showed in my post.
nbryan
Jan 3, 2019
1,224
761
As far as I know the separate-seat subframe is for a cabbed model. A rops model gets a different main tractor seat, a swivel seat.
Donystoy
Dec 10, 2013
552
204
Binbrook, Ontario
If it is similar to the LX2610 the rear mounting of the frame to the tractor is probably different between open station and cab model due to the cabs lower structure. Backhoe is also moved rearward another 9 inches with extenders mounted to the backhoe.
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
Thanks everyone , I’ll look that up but I think I might just buy the kit from the dealer . Wonder why his is the separate seat cab model subframe , he is rops no cab
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
Got it , so if I was to use his backhoe the seat would be with it and would probably mount just the same ??
3,566
I'm pretty sure that if you were to use his hoe (from an L series) his would have the extra seat. In that case, you'd need the subframe for an LX with the extensions for a cabbed model. There are also two separate types of backhoe control sticks. The extra seat version uses short-straight sticks. The longer bent sticks are used on tractors with the swivel seat. Those sticks come up much higher because the seating position is higher and further away from the backhoe unit.
However, I do think there was someone on OTT that rigged up the BH77 with seat and without the frame extensions.
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
thanks for that info , li would probably go the way of the rops version for the lx , I was only thinking of borrowing it maybe once / maybe not . I always figure if I borrow and break it I have to buy two . So that’s why I bought my own tractor . Question though which is the better way to go for the lx and why does the non cabbed L3902 with rops come with the cabbed subframe . Thanks for all the help , seems it’s about $1180 for the kit so I’ll put some money aside here and there and install that . At that I think you could probably modify any backhoe setup to mount on that
S-G-R
LX3310
Jun 17, 2020
1,079
2,191
PEI Canada
For a one time use I'd just look at renting a mini-x.
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
So I’ve been looking at backhoes on marketplace . There are quite a few at fair prices . I see a few Bradco but specs are heard to find . I’m looking for something with similar specs to the bh77 , I found a few model 408 but there are no specs on that model to be found . I’m figuring I would buy the kubota factory subframe and modify the backhoe to connect on that frame . Any thoughts on direction to the specs/ or best Branco model to use . Thanks , Richard
Rnscustom
Kubota LX2620
Jun 22, 2024
37
14
Massachusettes
Is Branco a low quality backhoe , I understood it was right up there with woods . I’m only figuring I’d get something needing some paint , hoses , and the fabricating of a bracket to match the factory kubota bh77 ( intend on buying the kubota sub frame ) . $10,000.00 for the kubota hoe isn’t gonna happen unless I hit the lottery . Not looking for cheap , just sweat equity . Thank you for the heads up on the quality issue .
5,055
"Branco"??????
= Bradco ????
