Learning to sharpen HSS lathe bits......A lesson in futility.....
2,359
Why abandon triangular inserts? These are cheap - MSC is not
No sir, I am not abandoning that.
I totally believe you about using "cost effective" bits.
I basically 'shot my mouth off" before I finished watching that video
I was just trying to "decode" which tool holder to get for my machine.
Stay tuned.......I'm still watching that video.
2,359
So I have some questions about the choices for the characters.
I need help in filling in the 3 blanks
M-------- pin and clamp
T-------- Triangular inserts
_---------Need help this one (tool holder style.....lots of choices and I haven't a clue)
_---------need help here too. ( Rake angle positive, negative, neutral......again no clue)
R--------Right hand tool
08------1/2 inch square. (this is the biggest my QCTP will accept)
_--------Need help here too (
A--------4 inches long
MT ? ? R08_-?A
in the background of @TheOldHokie post, I see a 1/2" version of what he sent me
https://www.ebay.com/itm/3003527608...brand=Shars+Tool&_trksid=p2332490.c101224.m-1
but that is a
Model# MTAN R-08-2A
  • Shank Size Square: 1/2"
  • Overall Length: 4"
  • Insert I.C: 1/4", T: 1/8"
So that is a negative rake, and the IC is 1/4 not 3/8......Big deal or not?
3,929
MT ? ? R08_-?A
https://www.ebay.com/itm/300352760812?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=271845,271023&meid=27de54f8fa7a4390b54a032771ed274f&pid=101224&rk=4&rkt=5&sd=300517030246&itm=300352760812&pmt=0&noa=1&pg=2332490&algv=DefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall&brand=Shars+Tool&_trksid=p2332490.c101224.m-1
but that is a
Model# MTAN R-08-2A
That will work but I consider it pretty light. You should be able to find a tool block with 5/8" slot to fit your tool post. Or you can always grind a 5/8" down to fit a 1/2" block.
You are in the learning/experimenting phase so I would suggest you dont spend a lot up front.
Yooper
3901 LA525
May 31, 2015
1,481
458
NE Wisconsin
It was so easy when I first got into this game. It was generally triangular and square inserts. Negative rake tooling was just starting to come into its own. I can’t keep up with all the different shapes and geometry and where they each shine. I’ll take a few pictures of what I use on my lathe and pass this on to you.
2,359
Thank you. I appreciate it.
What rake angle do you suggest?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
854
648
canada
Gotcha! (y)
Well i found a video that seems to explain how to "decode' the "alpha-numeric soup" of tool holders.
The guy seems to know what he is talking about and so I took his logic and came up with a tool holder number of
MCLNR083A
I made some assumptions on how to massage the numbers..........like going with a 08 instead of his example of 12 and went with A instead of B, in order to find a tool that will fit my machine.
Low and behold the inter-web kicked back a holder that might be what I am looking for?
https://www.mscdirect.com/product/details/05696711
Any thoughts?
great video, I have watched some of his videos before. He seems quite knowledgeable. I don't own a lathe, I just like watching stuff being made.
Yooper
3901 LA525
May 31, 2015
1,481
458
NE Wisconsin
Oh man! That is a very good question to which I have forgotten through the years. I will post a link to a conversation on Practical Machinist that may or may not enlighten us to help answer this.
I’ll post pictures in a couple of days of what I use. Couldn’t get it done today or tomorrow because I am retired and my days seem to be taken up by other peoples plans😖
