L4150 clutch issue
Mdman
L4150 and BF900
Feb 5, 2023
Hey there, thanks so much for reading this. I have a L4150 and the clutch suddenly stopped engaging. The clutch peddle goes all the way down with no resistance. I checked the linkage and it’s good. I greased the zerks. It was scary when it went out. I almost crashed into my truck because the clutch didn’t engage! Thanks so much for any advise.
5,714
Sounds like you've broken either the pressure plate or the clutch fork.
You're going to need to split it to find out.
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
58
79
CT
I second the throw out bearing fork… check the shaft also.
Must times its not the pressure plate that fails if its not disengaging. Any way to grease bearing or plate to inspect before you split it?
