Hoist pad project. The adventures of RWS continue!!!!!!!
2,343
First off, I apologize to any Machinist, Weldor, or seasoned Fabricator. What you are about to see is simply “what I know” and I mean no disrespect and do not claim to be a “tradesmen”. (y) (y) 🍸
I’m just a guy that likes tools and metal working; I am in no position to “give advice”, just having fun.
Carry on!!!
So there I am, wanting to use my hoist to lift my tractor to work on it.
After some “looking around” I find an idea that intrigues me.
I wish I could remember where it was from, and who came up with the idea, but I can’t.
Anyway, its basically “large footprint hoist pads”, so you can drive up on them, secure the front tires, and safely lift my tractor.
The first one I made, was “Pre-Langmuir” so I drilled everything “old school”
However the next 3 were cut using my Crossfire Pro!!!
Wow, that is a game changer for sure!!!
Here I am cutting out the “plates”…Took about 45 seconds per plate, after I got them “aligned”
IMG_0106
IMG_01061920×2560 338 KB
from a different thread, I had to use “witness marks” to try and get each plate cut “about the same”
IMG_0109
IMG_01091920×2560 161 KB
Then it was off to the lathe to turn down the ends of the parts that will go into the hoist and eventually be welded to the above “plates”.
IMG_2668
IMG_26681920×1080 368 KB
First I “face it”
Lock tool making 1
Lock tool making 11920×1080 227 KB
Now I turn down one end to go in the “hoist eye”
turning 1
turning 11920×1080 400 KB
I haven’t learned how to use the cross slide to actually measure how far I have cut, so I just have to “creep up” on it, and keep checking it.
turning 2
turning 21920×1080 352 KB
Not a great finish, so I “cheat” and get some “emery cloth” to clean it up a bit.
turning3
turning31920×1080 240 KB
Now I flip it and turn the “plate side”, but my battery died, so here is the end result of the “turned pieces”
IMG_0117
IMG_01171920×2560 364 KB
I since they are so big, I decide to “pre heat” them so I put them in the oven at 500 degrees for about 1.5’ish hours.
IMG_0119
IMG_01191920×2560 320 KB
Here is the first pass…My “welding positioner” crapped out on me, so I had to go “old school” and had to keep stopping to turn the piece.
1st pass
IMG_0120
IMG_01201920×2560 306 KB
2nd pass. For some reason my subsequent passes, never look as good as my first…
IMG_0127
IMG_01271920×2560 321 KB
3rd pass
IMG_0134
IMG_01341920×2560 331 KB
2,343
Now I weld the “topside”
IMG_0115 2
IMG_0115 21920×2560 310 KB
IMG_0137
IMG_01371920×2560 371 KB
For those unfamiliar here is a pic of the hoist arm ready for my truck.
IMG_0139
IMG_01391920×2560 451 KB
here is it when that “hoist pad” is removed.
IMG_0140
IMG_01401920×1440 257 KB
Now for the “Tractor pads”…but first here is a pic of what happens when you let your grandkids play in the garage… :LOL:
IMG_0141
IMG_01411920×2560 390 KB
IMG_0141
IMG_0143
IMG_01431920×2560 419 KB
IMG_0144
IMG_01441920×2560 334 KB
IMG_0145
IMG_01451920×2560 376 KB
Yooper
3901 LA525
May 31, 2015
1,477
456
NE Wisconsin
I’m suffering from hoist envy! Starting to get cnc plasma envy!
Here is a sample of what you can use to measure your cut distance with accuracy. I prefer the magnetic style. You can find these in any machining supply catalogs or on eBay, Amazon etc
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
57
79
CT
Great timing. Actually thought about this couple days ago.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
842
640
canada
I like it a lot. I am guessing you are also making some removable ramps so the tractor can drive up on them without flexing the plates.
2,343
Yes sir (y) ; Ramps are in the future. As soon as my shoulder heals a bit more, I'm gonna go pick it up, so I can have it here to "measure" .
2,343
Be careful.......those are "envys/symptoms" are dangerous......
Also thanks for posting that.....I will have to look for one of those for my Craftsman bed.
MOOTS
MX6000
Jun 27, 2019
1,849
2,093
Canton, Georgia
I see your lift has lock pins, so the arms won’t swivel while they are raised. Hopefully they work.
How will you secure tire on that pad?
2,343
Each pad has 4 holes, so I plan on using a "ratcheting tire hold down" (on the fronts at least.)
Ktrim
Dec 23, 2020
339
195
Nazareth Pa
So let me see if I'm reading these posts correctly.
You have a wife that lets you put a plasma cutter in the basement and steel parts in her oven.
One more thing to be jealous of.
2,343
Well, I suppose that depends on what the definition of the word "lets" is? ;)
