Are these the same as automotive fuses? Z726 fuse.
Sidekick
Kioti CK2620SE cab, RTV-X, BX3260, Z726XKW-3-60, Deere 4100
Jul 29, 2023
332
281
N.Y,
Today I got done mowing on my Z726. Turned it off to blow it off then tried starting it. Just click click click and found the battery had died. Found a blown fuse and it's a strange looking fuse rated at 30 amps.
Looked it up at Messicks and it's a $14.00 fuse so my dealer would probably be $20. Wondering if this can be interchanged with something from the automotive world that would be lower cost until I find the problem incase it blows again. Seems to be about the same as something called a jcase fuse that I found on Amazon. About 10 hours ago my voltage regulator was replaced under recall and this seems to be in that circuit but it's hard to tell the way Kubota wraps all the wiring together and just leaves everything hanging. Wondering if anyone has tried a non Kubota fuse?
3,270
Looks like it… get your calipers out and measure it…
Sidekick
Jul 29, 2023
332
281
N.Y,
Thanks. Just measured and close. The Kubota fuse is about 16mm tall and that looks like 16mm to the bottom of the lip. I guess I will order a cheap set from Amazon to try. Really wonder why they use these fancy fuses Just hanging off the wire harness when atc fuse holders come with sealed lids that keep moisture out. Never saw a fuse like this before.
4,425
Cars have been using those fuses for many years now. When I go to the pick a part yard I usually fill my pockets with fuses and relays. I show them to the cashier when I leave, and they charge me a dollar or two. Even with my selection I occasionally don't have the one that I need.
2,756
1,255
They are not standard fuses, they are Slow-Blow fuses. They have been used on automotive, ag, construction, and even lawnmowers for over 30 years.
