Good box scraper with hydraulic rippers for 35 HP tractor (27 HP at the PTO)?
bennynihon
WA
I recently purchased a used B3350, which is 35 HP (27 HP at the PTO). I'd like to get a box blade that has hydraulic rippers, but I'm not finding many options. There's the Land Pride HR2572, but their website claims it's for 30+ HP tractors (which I'm assuming they're specifying at the PTO, since it is a three point attachment). I'd be just shy of that at 27 HP. While I still me be able to operate this to my satisfaction, it still would be the biggest implement I own (all fall in the 60-66" range). So I'm curious if there are slightly smaller options. Or is there a way to add hydraulic rippers to another box blade, such as the BB1260? Or would you just go with the HR2572? Thanks for any advice.
S-G-R
LX3310
Jun 17, 2020
1,050
2,097
PEI Canada
They would be basing the hp as engine hp since it doesn't have a pto. You will probably be more limited by the weight of the B3350 pulling it vs using a heavier L series.
bennynihon
WA
Ah, yeah that was stupid of me to say. Definitely not a PTO implement. So I guess I'm now really just looking for recommendations for smaller box scrapers than the HR2572 that also have hydraulic rippers.
S-G-R
LX3310
Jun 17, 2020
1,050
2,097
PEI Canada
I think a former member on here retrofitted hydraulic rippers to a boxblade. Was it Sled dog? Can anyone remember who it was?
Fishhook
M4 HRL3584, RCF3696, HLA3230, B2650 w/everything
Jun 15, 2021
11
Alaska
Benny, I'll compare my B2650 with a BB1572 and R4 tires to my M4 with a HR3584 with R1 tires. M4 tractor weighs nearly 8,000 lbs and the HR3584 weighs 1097. The B2650 weighs 3200 and the BB1572 weighs 850 (I added 500 lbs of 1" plate steel). I just used the M4 with the HR3584 to break up a 15 year old gravel parking lot that had huge chunks of concrete, asphalt, tree trunks, cinder block, and a fence gate post set in a piece of concrete 36" x 12" (it had been cut off at ground level and I couldn't see it). I used the scarifiers to rip down about 6" to get the pot-holes. I could travel at 5.4 mph in the M4. For several years before I got the M4, I maintained the 1.3 mile unassured road I live on. It's been here for 13 years and serves 15 homes. It would take me 14 hours to blade the road, traveling at 1.6 mph (prior to adding the weight, it would take about double the time, but I could travel at a much faster speed. I can do the same road with the M4 in 4 hours traveling as fast as my back and kidneys can take.
The hydraulic rippers are all the way up or all the way down - you can't use the hydraulics to drop them down half way. I didn't need the hydraulic rippers, but I got a good deal on the HR3584. I broke one of the shanks off working on the parking lot. With shipping, that cost $40 with $50 in shipping.
Your 3350 will work, but you won't be able to just drop the blade in any material.
5,702
Yea rippers and any size of box blade and your going to drag that B3350 right down to nothing.
You don't have enough HP and weight.
What are you wanting to do with it?
