Tire confusion
Digividsmith
Kubota B2400
Aug 12, 2024
Centerburg, OH
I a relatively new owner of a B2400, and I'm looking at replacing tires. The rear set are the Ag type, and the front are the turf. Current rear tires are 31x15.50-15 NHS. Fronts are 20x10.00-10. According to my manual, I purchased a set of "Ag" style tires that are 7-12, but they look way too high and are questionable if they will clear the front loader. Given the turf tires are 10-wide and the new tires are 12. am I looking at new rimes too?
4,526
yes ! You can't put 10" wide tires on 12" rims.
Up here I can buy tire and rim CHEAPER than tire only.
For my BX23S rear tire is $500, same tire on rim $350.
FYI you should run same style tire on all 4 corners, else trouble can occour.
Digividsmith
Kubota B2400
Aug 12, 2024
Centerburg, OH
Good to know about width! But here's what scares me a bitt (see photos). That's quite a difference - and these are the recommended 7-12s.
Steve
4,526
well I'm really confused ! I looked at Kub CDA parts and that is the ag front, BUT the ag REAR isn't31-15.5x15......
dwg #s are R10102 for fronts, R11003 for rears.
Hopefully someone here can set us all straight !
Digividsmith
Kubota B2400
Aug 12, 2024
Centerburg, OH
Yea, if I could actually get those new tires on the existing rims, the tractor's nose would be up in the air :) And I doubt that I could turn the wheels without rubbing the front loader. Hard to say what the previous owner really did with it. Worse comes to worse, I could always put 20x10-10 (or 12) Ag tires on it and call it a day.
4,526
the 'deal' with tires is they have to 'match' front to back so when in 4wd, one end doesn't destroy the drive train........
Digividsmith
Kubota B2400
Aug 12, 2024
Centerburg, OH
So when you say “match” are you talking about tire size or tread type (or both)? Obviously, I have to deal with what the previous owner left me with, and the spec tires may not fit (or will fit if I replace all 4?) ouch. I was just shooting to somewhat match tire tread instead of having turf style on the front and Ag on the back.
4,948
Not sure why you want to put different tires on the front. I bought a B8200 brand new in 1985 and came with "turf' tires on the front and "ag" on the rear. Tractor had a loader and I used those tires until I sold the tractor 30 years later! Never had a flat on that tractor as long as I owned it.
