To flail or brush hog with L2501?
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
117
221
Mark Twain Forest
The neighbors used large equipment to mow and bail the easy fields. I am left with the small, hilly, tedious fields. Since the PTO output max is 15 HP, the maximum size mower I can get is 48" wide. So, the question is to flail or brush hog? From what I can find, the large equipment OEMs don't make small equipment. Has anyone used a MechMaxx flail mower?
thanks
Gary
rc51stierhoff
2,607
Good day.
4’ seems smallish for an L250X. I don’t really know that’s my opinion. 🤔
Why would your machine not run a 5’ cutter? (Personally I would try to cover the tracks). 🥃
rc51stierhoff
2,607
Mowers wider than 48" state PTO 25HP minimum. Outside my power range.
I would politely / respectfully encourage make sure looking at Pto Hp or KW rating. I think maybe it’s 19-20ish. I don’t know as a fact but I’d check before you buy. Could be a game changer for you what you can reasonably run. And the in that case I’d look at 5’ widths. I am sure some l250x owners will chime in. I don’t know myself for a fact but please check the math (respectfully).
ken erickson
Nov 21, 2010
1,061
1,700
Waupaca Wisconsin
My L2501 hst is listed at 19 PTO HP and a gear drive at 20.5 PTO HP.
Landpride matched implement guide recommends a 5 foot brush cutter for L2501's and I have been running a 6' light duty LP for 3 seasons now without issues.
My humble opinion it would be a mistake to think the largest rotary cutter you can run is 48".
1,153
I would go flail unless you are wanting to cut the grass pretty high, then rotary cutter
MountainMeadows
Jun 6, 2022
212
281
Poconos, PA
I've got a 5' brush hog behind mine, which has 19 hp pto and have never run into an issue mowing our meadow.
