Good in theory, sucks in the real world.
How to extend your enjoyment of cleaning the deck
Time to top up your life insurance policy and update your Power of Attorney for Healthcare and your Will...Don’t worry, I haven’t forgotten my roots.
That Kubota jack looks like the same mower jack sold by HF.I have used a hi-lift jack on my Exmark for years without a problem. I decided that I might be pushing my luck so I purchased a Kubota accessory that is no longer available. I had one at the farm and figured my life was worth the price of another one. I scrape my decks every time I mow. I have gone to the green side for a zero turn and it works for that as well. I have used the jack on my zero turns, the Kubota BX and the John Deere x590 and x739. I was happy to find my local dealer had one left last spring. I am leery of the screw type jacks as my brother had one that the nut wore out. Just my take on this. Do not go the Hi-lift method as I think I am somewhat lucky that nothing bad happened doing that.
John Deere offers the tongue type jack as an option on their zero turns. It would be something to look at. I figure you could source the jack for less money at an ag supply store.
Kubota Standard Duty Multi-Purpose Mower Lift
Item #77700-03669
Quickly and safely raise mower to comfortable working height. Easy access to under deck for cleaning, lubricating, sharpen/remove blades. Complete protability and flexibility ideal for the shop or on the job site. Equipped with 4 point positive engagement lock system. Accommodates most brands, makes and models.
- Lift Capacity: Wheel Stirrups: 350 lbs
- Width: Minimum Inside Wheel Width in Stirrups: 19.25 Inches
- Width: Maximum Outside Wheel Width in Stirrups: 51.5
- Inches
