Spring in oilpan
kabota723
B2601 Tractor
Jul 31, 2024
Colorado
Hi all. My 2601 stopped running and I pulled the oil pan to check piston clearances and I found a little spring in the pan. About 1/2" long and almost looks like a fuel pump spring but that is still there. Any ideas where this lil guy belongs? Appreciate the insight..
lynnmor
B2601-1
May 3, 2021
1,390
1,099
Red Lion
I don't know if it is possible for the oil pressure relief spring to make its way to the pan, maybe you could check that it is still there behind the oil filter. The part number is
#1J050-36950 SPRING
if you can find one at a dealer for comparison.
kabota723
B2601 Tractor
Jul 31, 2024
Colorado
#1J050-36950 SPRING
Awesome! Cool, I'll check that out. Thank you.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
814
616
canada
Does the engine still turn ? If it is the oil relief valve, that would mean no pressure/ little if any lub.
4,493
just the spring ?
I don't know that engine, but on others, there's a 'series' of check ball, spring, retaining cover,bolt so I'm wondering HOW just a spring got into the sump ??!!??
