BAP
Excellent advice!Build it for the next owner. If you had to sale what would add value ? I have 10x10 doors on my shop but could put 12 tall on the end wall. We built our RV shed 20/45 with 15 ft wall. I should have gone 50 ft as our current rv is 44ft from pin to rear
That is a thought. The hold up there is that we would like to build it as a drive thru. Doors opposite of each other so I could just pull through the building and not have to back it in. Of course, we all WANT things and don't get themJust a thought, use sloped, parallel chord trusses to get height in the center for the boat without the side walls having to be so tall. I, of course, don't have any idea what you're considering.
No. We just sold it 2 weeks ago . Had we kept it, the doors would have been 14' for sure.Does the possibility exist that you might EVER buy a motor home?
Our kids will be the one to sell it. Lol. Custom home, 9 acres in the woods. We aren't moving until it's in a pine box.Build it for the next owner. If you had to sale what would add value ? I have 10x10 doors on my shop but could put 12 tall on the end wall. We built our RV shed 20/45 with 15 ft wall. I should have gone 50 ft as our current rv is 44ft from pin to rear
This is true. Learned that at our old house. The garage had 7' doors but my 6" 9" truck didn't fitDon’t forget, a 12’ overhead garage door doesn’t give you 12’ of clearance.
I was thinking of something like this with a door at each end.That is a thought. The hold up there is that we would like to build it as a drive thru. Doors opposite of each other so I could just pull through the building and not have to back it in. Of course, we all WANT things and don't get them
+1 on 14' doorsNo question if it were me I’d go with 14 foot doors. You’re talking about a new build. I’m surprised it’s that much more of a cost to go from 12-14’ doors. Obviously cost of doors and materials go up.
What’s a ball park cost for your area between the two sizes?
Ah, I see what you are saying. I was thinking you were talking about a large loafing shed. So the roof would only be sloped in one direction. That way, backing a boat in, the stern would be at the low side of the building.
It's not the cost of the doors as much as the height of the building. My preference is to have the door offset to one side. So the door height dictates leg height. Increasing the leg height above 14' increases the materials- leg spacing is narrower also. So more legs. Probably has to do with wind and snow load. We would also have to use concrete footers.No question if it were me I’d go with 14 foot doors. You’re talking about a new build. I’m surprised it’s that much more of a cost to go from 12-14’ doors. Obviously cost of doors and materials go up.
You should probably consider talking with "Morton Buildings".It's not the cost of the doors as much as the height of the building. My preference is to have the door offset to one side. So the door height dictates leg height. Increasing the leg height above 14' increases the materials- leg spacing is narrower also. So more legs. Probably has to do with wind and snow load. We would also have to use concrete footers.
I don't recall the exact $ difference, but it was enough to make me think twice.
They just set yours on dirt?!?You should probably consider talking with "Morton Buildings".
They may not be the cheapest, but are nationwide,......... and Morton is a first class company.
I have a 36' x 48' x 14' Morton, built in 1984.
40 years old, and still looking great!
Concrete footings were not required!
You think boats are a money pit? Try racing! I'm trying to get back into boating to SAVE money!A bud has a 250 Dauntless Boston Whaler with a roof and rocket launchers, soo 10 feet from the deck maybe, the doors he has are like what you would see where they do big trucks, I dont know the height or how wide but BIG, anyway what he does on the off season, he has concrete floor so he will back the beast in and then unhitch it, jack up the trailer and set those wheel dollies under the axel wheels. And them he can move it to the side of the garage out of the way, and still do what ever he needs to do on her. I never got that much in to mine, but then mine wasnt 100k either. They are a money pit, but I still miss my boat
Yup!They just set yours on dirt?!?
I have looked into their products. They should have a slab or footers under your columns. I certainly would not want a wood frame on grade.
Foundation Options | Concrete Lower Columns by Morton
A strong building starts with a strong foundation. Morton uses concrete lower columns to help extend the life of your building. Learn more about our options here!mortonbuildings.com
Makes sense. You could offset it by using short trusses on one side and long trusses on the other, so you'd have one tall wall and one short wall. I don't know how that would affect the cost.Ah, I see what you are saying. I was thinking you were talking about a large loafing shed. So the roof would only be sloped in one direction. That way, backing a boat in, the stern would be at the low side of the building.
That's essentially what I'm thinking, but with the door to one side. It's a better use of space to have the large item (boat) on one side and room for the ATVs, MX bikes, tractor, attachments, etc on the other. If the boat is in the middle, the "extra" room is broken into 2 smaller sections. Does that make sense?
It's all planning stage right now anyway. To be honest, a totally enclosed building isn't even necessary. It is what I'm shooting for though.
Same thing. Those are footers set in concrete. Still boring holes and setting something in them then backfilling with concrete.Yup!
40 years ago, Morton drilled holes and set 6x6 PT wood posts.
Poured in a bag of dry cement first.
Posts all appear to be in excellent condition.
