Engine quits when I back up with PTO engaged. Holding the KRA button doesn't help. The switch checks out good. Any ideas?
Check your safety switchesEngine quits when I back up with PTO engaged. Holding the KRA button doesn't help. The switch checks out good. Any ideas?
Yeah, sorry. it's actually a GR2120. Not sure there's much difference. Manual has KRA as "Kubota Reverse Awareness" system. Been trying to fathom the electrical schematic, but it's too complex. Plus, there's no tie from the schematic to the locations of the various switches/parts. The dash push button override is the only one I've found that could be the problem thus far and it checks out.I would need to see the wiring diagram as some units are very complicated aka 'computer' .
I did find a GR2100EC WSM but NO 'KRA' switch, so must be another model.
This one has a grass catcher that appears could shut off the engine, which is really silly if true....
Seat switch checks out. What's the neutral switch?Check your safety switches
- Seat switch
- Neutral switch
Two most common if equipped with opc sometimes wires on plug corrode and damaged
